Can anyone help me with connecting the wires. I had to change the engine. I was not the one that disconnected the wires. I have 4 long ones, 2 go to Alternator. I think 1 to coil. That leaves 1. Do not now if it makes a difference but the rear half is 1954/55. Front is 1951. Thanks C Kain.
Re: CASE DC wiring in reply to C. Amick, 09-20-2012 05:05:34
Thanks, My DC has an alternator and what looks like a regulator, located behind the tool box. I haven't found a wiring diagram that shows a regulator. ?
Re: CASE DC wiring in reply to C Kain, 09-20-2012 18:32:24
The tractor originally should have had a cut-out relay or voltage regulator mounted on the 6 volt generator. The alternator was added by a previous owner. I assume the sytem is 12 volts now? If you look under the "Research and Info." then "Articles" on this web site, you will find a lot of information on converting tractors to 12 volts using alternators.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
Needing good 70 series fenders. No rust or dents preferred.
[More Ads]
