Case 930 cracked cylinder head.
MattLF9
I just picked up a 930 diesel and noticed I have antifreeze leaking out between the exhaust manifold and the cylinder head and the exhaust smells like coolant. Is the exhaust port cracked inside? Its not pressurizing the cooling system.
It could be a leaky head gasket also. If it is the center cylinder. it may be a gasket. The older ones tended to blow a center gasket if they were run too hot one time too often.
