Case 1959 800series transmission question
MIchael 27
New User
I have a 1959 Case-o-matic 800 seriestractor. What transmission fluid should be used? Case manual says sae ms-dg 10w in both converter and transmission. Trouble is I can't find 10w oil. Would Coastal multi-trac fluid in the green bucket be okay to run in both the converter and transmission?
Origanly it called for sae ms-dg 10w or type A ATF fluid.Now days oil blends are so much better and
Dexron III/Mercon is recomended.
