Case Tractors Discussion Forum |
Trouble shooting fuel starvation problems
Author |
[Modern View] |
Dallas Huybregts
07-10-2012 19:44:17
 Hey all, Last week I pulled my gas tank off and found the sediment bowl fitting was totally plugged. I cleaned it out, cleaned the tank and cleaned the fuel line. Today I made a new gasket for the sediment bowl and put some gas in the tank. Unfortunately I found the same problems, the tractor would run for a minute or so and then quit regardless of choke position. My next plan of action is to look at cleaning the carb but aside from that what should be my next trouble shooting steps?
Florida Glenn
07-12-2012 05:20:59
Re: Trouble shooting fuel starvation problems in reply to Dallas Huybregts, 07-10-2012 19:44:17
I had this very same problem on TWO Case D's a few months back. On one D, it was carbon build up in the exhaust manifold. On the other, it turned out to be the sediment bowl gasket was leaking air into the fuel line. Start the tractor and watch the gas flow through the glass bowl. If the gasket if bad, the gas will start to bubble and you'll see a drop in the gas level in the bowl. When it gets low enough, the motor will run out of fuel and stop running. When it shuts off, you'll be able to see the bowl filling with fuel again and after a minute or so, the tractor can be started again and it will repeat the same situation. Also, check to make sure vent hole on your gas tank cap is clear. Sometimes they clog up and fuel will not flow. Make sure bowl is seated properly.
Jeff B.
07-11-2012 21:02:28
I had a 311 that would do that. Ran for just a minute & died. Wouldn't start again for a couple hours, then it would fire right up. Couldn't figure it out till I looked at the other side of the engine while I it was running just after dark. Big blue sparks arcing from the coil tower to the small terminal. I changed the coil wire and it's never skipped a beat since.
Ron Sa
07-11-2012 09:02:53
When I have to unscrew a sediment valve asm from an old gas tractor, I always install a short stand pipe in the assembly: about 3/4 inch tall. Drill it to the OD of the tubing being used for the standpipe about two dia deep and locktite it in place. PS: Don't blast shop air into the carb fuel inlet with a blow nozzle until the carb is apart. This tends to colaspe the float. Those aren't cheap!!!
Christopher Mikesell
07-10-2012 20:15:40
First, what model tractor is it? Regardless of the model, I think that you should pull the plug at the bottom of the carb and let the fuel run out into a container for a few minutes. If it slows to a trickle, then the problem is upstream of the float bowl. If this is the case, check the sediment bowl again by removing the glass bowl and letting some fuel run into your container. If you get good flow, then your problem is between the float bowl and the sediment bowl. If you get good flow out of the bottom of the carb, then your problem is probably in the carb. However, what seems to be a fuel problem may actually be a problem with somthing else. Also, just because you cleaned the tank does not mean that it is clean. Varnish can flake off over time and plug things up badly. Filling a tank with more than a fraction of a gallon can help with this, since the flakes migrate the most when the fuel level is low.
Dallas Huybregts
07-10-2012 21:51:27
Re: Trouble shooting fuel starvation problems in reply to Christopher Mikesell, 07-10-2012 20:15:40
Thanks for the suggestions. It's a 1955 Case 410.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
