I am having a problem with the sensing link on my 1070. When I bought the tractor the c shaped part that goes over the crossbar was broken in half. I found a good used one and I took off the left lift arm and the left wishbone spring and slid it over the cross bar then put the left side back together. Any way when I was tightning the bolt on the back side of the c shaped piece I broke it in half also.
My questions are:
1. Do I have to the lift arm and spring and other items off to put the c shaped part on or can I tap it over the cross shaft?
2. If i am unable to find a decent used one would you weld it back to gether and use it?
Thanks for your input,
gramps
