Re: pic of other side in reply to Old Popper, 07-01-2012 15:25:37
Dale, I'm not a Case expert but I did a little Googling and found out Case had a 126 1/2cu. 30 HP air coled engine in a tobacco setter, and maybe some other machines, and it will fit in a vac. Wish I would have run over to Peterson for a viewing. Jim
Re: pic of other side in reply to Fixerupper, 07-01-2012 15:47:04
We took one in on trade in an A-6 Case combine in 1965. My guess is that it was about a 1955 machine. They guy who had it complained that the center two cylinders overheated.
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
