Company Logo (800) 853-2651 Shop Now
Case 444 travel valve
MasseyHarrisGuy
06-26-2012 18:25:11
This subject may have been beat to death and excuse me if it has, but I am having some trouble with the hydraulic drive on my "new" 444. I think its a late 60s model with the hyd imp lift on the right side by your knee. Anyway, when (most noticable) in high range you move the lever to go forward or reverse the lever needs to move really far to get the tractor to move. When you start moving it you get the normal groan like its loading the pump but you keep pushing further really slowly and then it all of a sudden catches and goes with a bad jerk. I looked at the linkages like was explained, and theres only 2 places where wear could occur. Those look really good. What I do notice is that the spool needs to move a good 3/8 of an inch from "neutral" to where the jerk occurs, almost like theres a "dead spot" in the valve. This happens in mainly the forward direction but not as bad in reverse. does anybody have any ideas what may be happening or is this just the common wear that is explained.
Thanks in advance
Frank
MasseyHarrisGuy
06-29-2012 15:51:33
 Re: Case 444 travel valve in reply to MasseyHarrisGuy, 06-26-2012 18:25:11
OK, Im going to try changing the hydraulic oil and filling to the proper level with the proper oil. I will report back with what happens.
Thanks guys!
Frank
1031D
06-27-2012 22:24:38
Sounds like the linkage is sloppy. I have a 195 and 446. Also, hydraulic fluid is not a good idea in these. Ingersoll will overcharge you for a few quarts of 20W-40 or most of us use Rotella 15W-40.
Klyde
06-27-2012 21:25:27
Are you using 20w-40 motor oil??? They usually act as you are describing when someone uses hydraulic oil.
jcmarleau
06-26-2012 19:23:55
Have a good look at your switch under the dash where your travel lever moves most likely that plastic switch is worn. jc
casecollectorsc
06-26-2012 18:49:08
The obvious, did you check the oil level in the hydraulic resevoir?!?
MasseyHarrisGuy
06-27-2012 17:16:46
 Re: Case 444 travel valve in reply to casecollectorsc, 06-26-2012 18:49:08
Oil level is about half full or more. I had the plastic neutral switch off weeks ago and got that to work as when I got the tractor there was no ground to the solenoid. So that fixed the no start.
For reference the tractor serial number is 9645209.
I was using the tractor tonight and it had the same jump when the lever was moved past the same point. Its almost like theres a dead spot in the valve. The linkage has a ball and socket at the bottom of the selector shaft and at the spool valve the rod is bent 90* and cotter pinned on both sides. I then moved the travel lever to full forward and clamped the spool valve to the valve body and tried to move the control lever. No play in the linkage that I can see or feel.
How full must the hydraulic reservoir be? I just dont want a mess if it decides to burp over.
Frank
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: Need for John Deere M Power Depth Control Bkt w lifting rod for long arm cultivator [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
