Case Tractors Discussion Forum |
400 diesel
Author |
[Modern View] |
jon f mn
06-04-2012 21:33:04
Used my big 400 on the blower the other day and it seemed to work good and have good hp, but no matter how hard I pulled it I only got a real light smoke. If you watch the video I posted you can see it at the end. At that point it was pulling about all it could. I always thought they would smoke quite a lot under full load. I have the pump set almost all the way open acording to the directions I got here. Also at low throttle the governor doesn't seem to work as it should. It won't open and pull at all unless you are at least half throttle. As I said it seems to have adequate hp, I'm just wondering if I have some other problem. Thanks.
oldproudvet
06-05-2012 19:29:27
Re: 400 diesel in reply to jon f mn, 06-04-2012 21:33:04
I've a low hour 400, excellent runner, but it does throw a bit of dark smoke under load, I've an 11 foot case disc, and if I drop it down in my loamy ground it'll snort. Where in MN are you? I'm North of Alexandria
jon f mn
06-05-2012 20:16:31
Re: 400 diesel in reply to oldproudvet, 06-05-2012 19:29:27
Dieseltech
06-05-2012 04:05:31
Not sure what size plunger is in your hydraulic head, but if it 7 or 7.5 MM size it won't have much excess fuel ability even with stop plate removed so you won't see heavy black smoke. If pump is original look on tag to find size, is listed just after PSB 4A, 70 is 7 MM, 75 is 7.5 MM, etc up to 100 which is 10 MM plunger size.
jon f mn
06-05-2012 04:18:33
Re: 400 diesel in reply to Dieseltech, 06-05-2012 04:05:31
Ok, thanks. I'll check when I get home. I never had a case with rotory pump before so I didn't know what to epect. Have had 730'3 though 1030's tho and they all smoked a lot more, thats why I asked.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
