2590 wiring problem
hello all, i have a 2590 that has lost the blower fan but everything else electrical works. i have no power to the blower fan fuse but everything else in the fuse block has power. Had this same problem last summer and replaced the relay on the frame by the starter and everything there still seems to check out, where do i go from here?? thanks in advance
As with anything electrical pick one end of the
circuit and start chasing your way to the other
end with a test light or multimeter.
Due to the obnoxiousness of getting to the blower
motor I would start at the fuse block and work
through the switch and then to the motor. I have
replaced the motor in my 2290 and I think I chased
it from this direction. Of course if you have
juice to the motor and no spin it is time to
replace the motor.
jt
whoops reread your post.
In my 2294 I have had problems with the light
circuit where it melted the fuse block and rendered
that slot unusable. You may have to put in a jumper
fuse holder.
jt
Gpurrs hit the nail on the head, sorry took so long to respond, been replanting and spraying. took that block apart and cleaned it up then had power to fuse block. then found the second problem the pin connecter where the wiring comes out of the roof into the back of switch panel. purple wire btw if anyone else runs into this problem
