Case Tractors Discussion Forum |
1070 Case 3 point
Author |
[Modern View] |
M tractor
05-22-2012 12:40:31
My early 1070 3 point is acting up it will lift my chisel plow only enough to clear the ground . When i started his morning it would lift it all the way up like it did before. Over the winter there was some water somehow got in to the hydraulic oil and would freeze causing things to not work at all . I changed the fluid and filter 4 times and now it is clean fluid. I have steering and brakes and the remotes work but the 3 point just will not lift it up . What is wrong ?
Agri King
05-23-2012 20:47:28
Re: 1070 Case 3 point in reply to M tractor, 05-22-2012 12:40:31
Did you drain all the plugs 4-5? including the one above the drawbar. Hy Tran only, no cheap farm store oil. If so the hyd pump may be weak, and should be flo-metered by someone who knows what they are doing. If you would like some more help check back in.
Mtractor
05-24-2012 06:28:36
Re: 1070 Case 3 point in reply to Agri King, 05-23-2012 20:47:28
Yes I pulled all the plugs to drain and only put the good hydraulic oil in it.thanks
Agri King
05-24-2012 11:11:09
Re: 1070 Case 3 point in reply to Mtractor, 05-24-2012 06:28:36
Are you able to have the hyd. pump checked out?
Mtractor
05-24-2012 16:11:28
Re: 1070 Case 3 point in reply to Agri King, 05-24-2012 11:11:09
I will get the pump pressure checked but I went out this morning and everything worked fine plowed about 4hours and no trouble kind of strange.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
Looking for two coulters and mounting brackets for a JI Case centennial plow
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
