Tractor Value
Tom Klugherz
New User
I have inherited a 57 Case 300B tractor with a bucket on it. It has not been run in years but did run fine when parked. I wish to sell it but have no idea of its value. I've been told $2500.00 but need input from someone who really knows. Any help would be greatly appreciated.Thank you
Tom
There is too many variables unanswered to give you a definitive answer. Pictures would help.
Does it not run because the engine is stuck? Does it have a gas or diesel engine? What is the condition of the tires and rims. What is the condition of the tin and fenders? Do any of the gauges in the cluster work? Does it have an eagle hitch and/or PTO. Power steering? Does the radiator hold water? Is the grill frame intact or broken/absent. Where is it located? What are the model and serial numbers on the tag (below the cluster, on the right side of the dash)?
It would need to be in very good original condition to reach $2500 IMHO. If the engine is stuck and the tires are marginal, it could be worth less than $1000. - Joe
(quoted from post at 10:09:59 05/14/12) I have inherited a 57 Case 300B tractor with a bucket on it. It has not been run in years but did run fine when parked. I wish to sell it but have no idea of its value. I've been told $2500.00 but need input from someone who really knows. Any help would be greatly appreciated.Thank you
Tom, that figure is subjective. How are the tires? How is the paint and sheetmetal? Oil leaks? Whats missing? How many places welded and where are they? Everything work like it should? Not running even if the engine is loose subtracts from the value. Are you in Case country, or Farmall, John Deere land?
Pics would help to get started.
The "B" series 300 didn't start until 1958. If it's a roundnose 300 series, it's not a "B". If it's the square-nosed 300, it's not a '57. Overall condition is a must see for evaluating a machine's worth. Like has already been said, tires, tin, functionality, and 'extras' add considerably to a tractors value, as well as location.A picture will do wonders to get you in the ballpark.
