Painting a S
well that depends on what you are using for a paint gun!! depends on the preparation and varies alot on certian painters!!! two coats of epoxy primer should cover it real well!!!two overall top coats should look good!!!! and i do paint tractors so!!!!!!!
I've never painted a full size tractor and I'm using an acrylic paint. So how much paint would you recommend I buy. I can get it mixed here locally so I can get more if needed. If I need a couple of quarts each then I suppose it would be cheaper by the gallon. I'm using a top feed gun.
Gallon of epoxy primer sealer! Gallon of topcoat!! I use ppg omni line of sealer and paint! Paint is a urethane! It turns out with a wet look! Tons of shine! !!! Get tech sheets on the products!! Ease use a good respirator! !! Good luck
