Company Logo (800) 853-2651 Shop Now
930 Case Diesel Power Steering
ratskinner
04-25-2012 16:04:15
The power steering on my Case is not working right. It"s still functional, but it is hard to turn the wheel still. Is there something wrong with the power steering or maybe just a trick that will get it working properly again?
Dodgeit
04-26-2012 11:32:38
 Re: 930 Case Diesel Power Steering in reply to jw, 04-25-2012 16:04:15
I found the nut had backed off that holds tension on the assembly insides. You have to pull the cover off the front of the unit that is in line with the steering shaft.
If you'll do a search for 700 series steering problems you'll find the thread I started that has instructions on how to fix.
caseman-d
04-25-2012 17:06:28
 Re: 930 Case Diesel Power Steering in reply to ratskinner, 04-25-2012 16:04:15
Check to make sure your spindles are well greased. We had a guy bring in his tractor because he couldn't turn it. We raised front wheels of the ground and it still wouldn't turn and we found the spindles were frozen do to old dried up grease.
caseman-d
Adirondack case guy
04-25-2012 16:10:21
Replace the PS belt with a cog belt and tighten up the new one as tight as practical.
Loren
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea ... [Read Article]
Latest Ad: John Deere DUBUQUE Parts for sale- 24 inch power adjust rims, 3 point hitch parts, Utility Rockshaft, Utility Anchor Yoke, 40 Standard ring and pinion, various 40 transmission gears. Other DUBUQUE parts available. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
