case 2090 fuel gauge
Anonymous-0
As i understand it the wires from the sending unit connect to the transmisson harness and from there to the cab wiring harness. what i need are the wire colours from the sending unit to the fuel gauge. For anyone with a wiring diagram it wouuld be of great help. The gauge now stays at all times at full, and it probably is the sending unit but would like to make sure sam
here are the scans I can scan the testing procedure also let me know, also if you want them bigger send me a e-mail at [email protected] and I will send them to you as attachments to see if it is the sending unit you can unhook the sending unit feed wire turn on key switch and the guage will go to empty if it is the sending unit if not it is the harness/connections or the dash connections or guage its self cnt
