I have been working on putting the original eagle hitch lift arms and links back on my tractor. Grandpa had put some other lift arms to better fit category 1 implements on it and fortunately kept the originals so I don't have to find replacements. I have been working on the adjustable link and was wondering how the bottom end of the rod is treaded into the casting that attaches to the lift arm. There is a gap between the threads on the rod and the casting so it doesn't appear to be directly threaded into it. I'm not sure if there is a nut up in the casting. I have studied the parts diagram and it doesn't seem to show how it is put together very well. I need to get this freed up so that when you turn the crank you can level the lift arms.
Thanks.
Thanks.
