Len Robertson
New User
I had a friend weld up the rusty areas in my VAO 28" rim and got ready to mount a good used tire I bought. But I noticed two holes in the rim and know I only have one valve stem! A look at the other rim shows there is a cast "block" (probably not the right term) on the inner side of the rim toward the hub. It fits inside the lug which the lug nut holds on. I assume it is there to keep the rim from rotating. So where can I get a replacement, and how does it fasten to the rim? Pressed into the hole? It doesn't go through a flat portion of the rim, so fabricating a replacement will be a challenge, although probably what I'll need to try if I can't get one somewhere. Thanks for any ideas. -
Len
Len
