triple range in a case-o-matic
J-J
I"m wondering if the triple range box will fit in a 400 or 600 case-o-matic? I"ve put a triple range in a regular 4 speed with the assistance of a donor tractor. I guess I"m trying to ask if the triple range box will physically fit where the dual range box is. I"m trying to put together the hundred series and really like the triple range. I thought it would be neat to have all the little ones the same.
thanks for any replies
I think it would be to long as the triple range box was designed to work with the live power pto clutch. Might work if you modify the shaft.Case didn't couple the triple range to the COM because the axels wouldn't take the tourqe.
