Dual batteries
Author |
[Modern View] |
trap4x4
02-18-2012 18:35:28
Well i did do a search, but that just confused me ... :roll: I want to add another 12v bat to my case 830 diesel ( W/out any glowplugs). Is it best to connect the second directly to the starter and its own ground? or to connect them together(not sure about parellel or in series)
Thanks
mEl
02-19-2012 11:18:06
Re: Dual batteries in reply to big bad bear, 02-18-2012 18:35:28
I converted my 830 lo profile diesel to 2- 12v 1000 amp Dekas with the bolt type terminals instead of lead posts, best thing I ever did, we made cables with eyes for all the terminals and cabled it with heavy truck type cable. I have a Delco alternator with a special lo rpm kick in regulator and it's charging as soon as its running. It will start at any reasonable temp with just the manifold heater and our Pa. winters can be cold. I never thought the battery boxes on those tractors were bad with the slide out latches, kinda brings the batts out where you can easily get to them. I won't argue about the 8D as it seems you can never have enough battery although I have never ran the 2 -1000's low. mEl
dboll
02-19-2012 11:09:06
Re: Dual batteries in reply to trap4x4, 02-18-2012 18:35:28
2 -6's get hooked up in series for 12v, 2 -12v's get hooked up in parallel for 12v, 12-12's spin faster but not as much reserve as 2 6v's, considering everything I prefer 2-12v's
Mike in Mn..
02-19-2012 07:35:32
About a dozen years ago I got rid of the dual battery set up and built a box for one of those great big (8D??) batteries with both posts on one end, mounted it half under the platform on the right side, just an angle iron frame with a hold down. Ended fighting those heavy batteries under the fuel tank and cleaning posts and connections. Those big batteries last forever. Best modification I ever did on the old 830.
trap4x4
02-18-2012 19:34:59
Thanks gents ... that clears it up well ....
John Saeli
02-18-2012 18:56:44
2 12V's hooked parellel is a much better set up than 2 6V's. In a parellel set up, the NEG post of each battery goes to Ground, & the POS of each battery goes to the starter. It will use less cable to come from the POS term. of the back battery to the POS of the next battery, then to the starter w/ one cable. Then, a cable from the NEG. term. of the back battery, to the NEG term. of the next battery, then to ground with one cable. Good luck.
Don Rudolph
02-18-2012 18:51:57
We switched our 930 to 2 12 volt bateries by getting custom made cables that connected both positive posts to the starter and both negative posts to the ground. It really helped starting. Don
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe.
... [Read Article]
Latest Ad:
Wanted front suit case weights and rear wheel weights for a 1456 international.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
