Company Logo (800) 853-2651 Shop Now
case dc headlight lenes
dc in illinos
01-30-2012 02:41:10
I was trying to get my head lights to work and broke the light and this was a original sealed beam light I would like to convert these units to reflector and bulb assembley to replace the sealed beam units but everywhere I look they only sell the compleat light and the parts that you can get are only the 5 inch light parts can any one shed any light on this matter no pun intended.I am finding not many repaire parts to be had the old case/ih web site also shows a number for replacement and I called carter and grunwald in juda wi.trying to find replacement parts but no luck does any one have any ideas
thanks bob
NickatKY
01-30-2012 07:26:10
 Re: case dc headlight lenes in reply to dc in illinos, 01-30-2012 02:41:10
I think the trim ring is different when using a sealed beam.
How come you want to change from a sealed beam?
I would be interested in your trim rings if you end up not using them.
Nick
dc in illinos
01-30-2012 10:04:07
 Re: case dc headlight lenes in reply to NickatKY, 01-30-2012 07:26:10
Nick I hearr what you are saying but I was trying to get as close to original and have you tryed to find a good 6 volt sealed beam even if it doesent have the guide logo on it but ,If I decide to replace with after market i will get a hold off you ,best i can do for now thanks for the reply
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
