Re: Eagle Hitch S in reply to Tommy Railsback, 01-26-2012 07:00:56
i have a 1952 s standard with the EH housing. it also has the bottom brackets that hold the EH arms and the bottom part the lift cylinder fits into. it has dual hydraulics. no top bracket and no EH arms. i will need to get the build card to see if it actually came with EH or not.
Tom,
I have seen several D's with Eagle Hitch, so I'm guessing S tractors should have it as well. Kind of hard to imagine it working very well on those low models though. Don
Re: Eagle Hitch S in reply to Don Rudolph, 01-26-2012 12:15:16
Parts book shows different draft arms, mounting brackets and lift links for the S as compared to the SC. It is blank under the listings for the SO which may indicate they were not available with 3 pt. Lee
Any "S" Series built from very late '51 on, will have the housing w/ E-H capability. Whether any straight "S" tractors had the E-H, I don't know. In looking through the old books, I found E-H available on the DI, which hugs the ground like an "S".
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
