I have finally been able to start disassembling the engine in my 400 diesel and have a few questions. I found as I expected that the engine was pretty well worn out. Much to my surprise the engine has 4-1/8" bore M&W pistons. What I'm wondering is what is the part numbers for the rods and the crank for the 251 cu. in and 267 cu. in. engines and are they interchangeable? I don't think the rods are original because the caps are split at an angle to the rod instead of perpendicular to the rod. I'm concerned that the rods may also be M&W and I may not be able to get replacement bearings since M&W is no longer in business. Would I be better off to get refurbished case rods? I am planning on replacing the sleeves and pistons since the ones I have are shot.
I am planning on having the heads, block, radiator, and water manifold cleaned and pressure tested since engine oil is being pumped into the antifreeze and I haven't found any bad gaskets that are leaking. I am also wondering is there is anything else to watch out for when tearing down and reassembling this engine? Are there any parts that aren't available anymore that I need to save?
