JH
on the 1030 trans cooler i been looking @ one it has the single fan belt but dont have the lines runing back along the side of engine block to trans any ideas or info would be helpful
1030 did not have the trans cooler on the earliest models when they came out in 1966. They came standard equipment in 1967 and I think late '66 models as well.
ok thanks lamont is there any way to put one on one or is it too much of a hassle or did they make something inside the tranny for all that such pump etc to circulate fluid
What are you going to do with the tractor? Unless your going to hook it to a 6 bottom plow and pull it in 3rd gear all day you probly won't need it. The tractor lasted over 40 years without it now. Just sayin it may not be neccessary to bother with it.
Well i was gonna use it as heavy tillage tractor the serial number 8298810 which makes it a 66 what would be the value of it run good everything works sheet metal is good paint is good for orginal
There is a guy in the picture adds trying to sell one for $4500. He's in canada but says he can haul it to iowa. Looks real nice but don't think it has 3 point.
