I recently purchased a 1955 401 diesel from my grandpa. It sat in a shed for 14 years and I was able to get it to run after going through the fuel system, rebuilding the starter and replacing the batteries. The only issues that it has are that it burns oil (I was told this) and it is pumping engine oil into the coolant. I suspect that it has bad head gasket(s) or a cracked head since the only other place I can think of where oil could get into the coolant is the oil filter housing and it isn't leaking there. Is there any other place where oil could get into the coolant that I'm missing?
I plan on overhauling the engine to remedy the oil issues and freshen it up the but have a question. It is my understanding that pistons are no longer available for the 251 cu. in. engine (4" bore). One available option is to get sleeves that have been bored from 4" to 4 1/8" and use pistons for the 267 cu. in. engine (4 1/8" bore). I was wondering if someone has done this and what they thought of the results? I'm a little concerned about removing 1/16" from the sleeves, mostly overheating and longevity of the overhaul. I plan on pulling the 4-14" plow that its rated for when I'm done with the restoration and I don't want to have to baby the tractor because of the thinner sleeves.
Is there a place to get the correct (4" bore) sleeves and pistons for this engine? Case claims their not available.
Thanks,
Eli
Thanks,
Eli
