300, 310, 311, 312 Tractors ..Decals?
rasman57
Did the rear of the seat have a CASE decal on my 56 310? Any reference for the PTO safety decal, the Triple Range speed per gear yellow decal? How about the safety decal about turning too sharp? Got a new set of decals and need a good original reference. The old tractor had been painted over a couple times. Gonna put the restored Davis Loader on then the fenders........ Thanks.
Rasman,here is a picture of the back end of my "310",and its never been painted,can see all decals,so here it is
Ok help me out Rasman,I have a shift leveer on the left,and one on the top of the trans.
On your's you have one on the left,top of the trans,then one on the right.What is the shift lever on the right??
a Cae man like you and you don't know what a high/low or triple range lever is ??? just joshing you buddy will get a book to you so you know your controls cnt
Tom,then mine doesnt have high and low range?? As it doesnt have the right lever
Ande, lever on the left is a hand clutch for ground travel. Lever forward is engage, back is disengage. When the foot clutch is engaged and the hand clutch is disengaged the pto continues to run with the tractor stopped. Used to clear baler, bush hog, etc. Early Case version of independant pto, but not quite. Case billed it as "constant running pto.
Lever on right on rasman5's tractor is a triple range gear train, high, direct and low. With triple range and 4 speed transmission provides 12 speed forward and 3 reverse. Your tractor doesn't have the optional triple range only 4 speed.
Pic is my '56 310 with hand clutch & triple range same as rasman5 has.
Joe
Thanks Ande. The seat will get a CASE decal. The PTO warning and TURNS warning along with the Triple Range speed chart decals are next. The 4 speed for most chores works fine but the Triple range is nice for finding the right speed for some things like creeping along with a mower or flying down the country road at 20 mph going to a field etc. I use mine for snow removal with a loader so the basic 4 speed would work ok.
The side panels are made by Roger H from the forum. He really does nice work. Restored my gauge panel as well. Those homemade ones with the vents are really nice too! That's skilled work.
