DC W/wet clutch
stumper
What is the best engine oil to use with a wet clutch? Detergent,non detergent,strait weight or multi grade? thankyou in advance,stumper
The clutch uses whatever oil the engine uses. It's fed from a hole in the rear of the crankshaft into the clutch housing, and is subsequently drained back into the engine sump. When changine the engine oil, be sure to drain the clutch housing. When refilling the engine be sure to add an extra quart for the clutch.
P.S. An operators manual will tell you every thing you need to know.
