Case Tractors Discussion Forum |
1370 - 2670 Crankshaft: Same or Not
Author |
[Modern View] |
Lamont
12-18-2011 20:16:36
I'm still thinking about this 2670 with the crank that's probably bad. I'm also thinking that the crank out of this salvage 1370 won't fit, but I'm not sure on that. So you guys who know more about it than I do please tell me. Is the crank in a 1370 the same as a 2670? The salvage 1370 that I have was a fairly new rebuild that sat and stuck after the owner passed away. It has been stuck now for about 5 years and I've had no luck breaking it loose. Should have a good crank and LOTS of other good parts, but I just don't know if it is the same as a 2670. Thinking not.
wilson ind
12-19-2011 07:08:15
Re: 1370 - 2670 Crankshaft: Same or Not in reply to Lamont, 12-18-2011 20:16:36
hAVE REALLY GOOD luck eith engine release and following their instructions of vibration on breaking loose engine. Put pressure on crank in one direction and set up something to vibrate long term switch direction occusionaly
Nedd
12-19-2011 05:45:55
Aftermarket bearings are different So I would say they are different. 2670 and 4690 have larger mains.
John Saeli
12-19-2011 07:18:53
Re: 1370 - 2670 Crankshaft: Same or Not in reply to Nedd, 12-19-2011 05:45:55
The supplier whom I trust, shows the same part number for the Mains & Rods on the 1370 thru to the 4694. Stands to reason that if CASE shows the same part number for the crank, that the bearings would be the same. Get that tractor home!!
Nedd
12-19-2011 18:23:23
Re: 1370 - 2670 Crankshaft: Same or Not in reply to John Saeli, 12-19-2011 07:18:53
I stand corrected. Now I won't worry so much about bumping up hp on 504's.
mEl
12-19-2011 03:14:53
Re: 1370 - 2670 Crankshaft: Same or Not in reply to Case Nutty 1660, 12-18-2011 20:16:36
The parts site shows the same PN for those two cranks. mEl
Jerry he
12-19-2011 02:55:19
Go to www.stollerih.com and click on parts on left side then click on parts arrow in middle of page then go to bottom of page and select Pontiac Store. This should open their parts book.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
