Company Logo (800) 853-2651 Shop Now
2670 Crankshaft - Need help/advice
Lamont
12-17-2011 19:54:52
Ok. Neighbor's 2670 is down. I'm still thinking about buying either the whole tractor or just parts and engine or parts and parts off the engine. To give a little history on this tractor; it was "rebuilt" about 200 hours ago, top to bottom. It developed a knock, then spun a bearing. Crank was taken down 0.020" and put back together with a NEW rod. Went back to the field and all seemed well until it got into a hard pull in some heavy/damp soil. The knocked developed again and quickly spun that same bearing again. Measured it today to find the damage is right at the 0.030" mark. What do you guys recommend on this one? The turbo has about 200 hours on it. The heads were rebuilt 200 hours ago. Injector pump is definitely good. Has 200 hour pistons, aleeves, rings, wrist pins, rods, (less the one bad one), good hydraulic pump, transmission shifts good, radiator is good. Is the crank salvagable? What's the value of this thing whole or value of various parts? If I don't buy it, it's probably going to the other neighbor's scrap yard and I sure hate to see good parts go to waste. He wants $2500.00 for it, but I can't see it being worth that. However, it will probably weigh out $2000.00 at the other neighbor's scrap yard.
RGMartin
12-18-2011 13:07:57
 Re: 2670 Crankshaft - Need help/advice in reply to oldironman, 12-17-2011 19:54:52
I have local shop has treated me really well. I hesitate to give out information for for fear of causing a backlog. The last 2 cranks have been within .0005" of where I wanted them, I can't ask for any more because I don't have anything that will measure any better than that.
brokengun
12-18-2011 12:54:07
 Re: 2670 Crankshaft - Need help/advice in reply to Lamont, 12-17-2011 19:54:52
If were talking about a complete 2670 for $2500 with a bad rod journal I would say heck yes it’s a good deal.
Is the Babbitt on the rod bearing pulled or full of metal?
If it’s pulled it was probably too tight when it was installed if it’s full of metal than odds are the crank oil hole was never cleaned out properly before installation.
If the rod is .030 no it will probably need to be taken to .040 before its cleaned up.
P.S. this is along the same subject line but have any of you guys noticed the quality of head and cranked jobs have gone down hill?
Locally we used to be able to get heads and cranks turned now we can’t even get valves ground. It seems like when the old guys retired the quality of work went to heck in a hand basket.
mark in boonville ny
12-18-2011 12:11:59
not really sure. you should ask a machine shop or maybe a dealer. that is probably your best bet or if somebody else knew.
John Saeli
12-18-2011 09:50:44
With what you describe being done, she's worth $2500 all day long. I would check for a blocked oil port. If it was near me, I beat a path to his door with the $2500 pretty fast.
dwag
12-18-2011 19:41:42
 Re: 2670 Crankshaft - Need help/advice in reply to John Saeli, 12-18-2011 09:50:44
Agree on blocked oil port thing, rods are lubed thru neighboring main brg journal. Either blocked port in block or crank main journal, possibly main brg installed with wrong half(one w/o oil hole) misplaced in block rather than cap. BTDT
Lamont
12-18-2011 10:41:28
Could the crank be taken down to 0.040" or is it ruined with the damage being down to 0.030" mark? I don't even know if rod bearings are available past 0.030" or not.
John Saeli
12-18-2011 13:52:21
 Re: 2670 Crankshaft - Need help/advice in reply to Lamont, 12-18-2011 10:41:28
.030 is the limit. Some shops have the ability to "spray weld" a journal back to standard or whatever. A good used crank wouldn't be hard to find, but for $2500, look at all the other parts you get.
12-17-2011 21:00:49
i dont remember what it was. it was a few yrs ago. check allofcraigs.com there might be something. im sure there is a good used cheap one out there. even if everthing else it is good it might be worth a 3rd chance. i would be interested in it if it was closer and cheaper. did dc-741 ever scrap or fix his 2670 maybe he still has his and might have the motor.
12-17-2011 19:57:57
that would be a shame to scrap. offer him scrap price. i would almost be interested in it if it was closer and he wanted less. my 4490 had spun a bearing just shortly after a rebuild too. my crank had to be shipped out to the carolinas to get redone. i didnt put more than about 30hrs on it after and i sold it and its up by vermont.
This post was edited by mark in boonville ny at 19:59:39 12/17/11.
Lamont
12-17-2011 20:51:56
 Re: 2670 Crankshaft - Need help/advice in reply to mark in boonville ny, 12-17-2011 19:57:57
I've offered $1650.00 for it, but NO GO so far. He's convinced it will bring $2500.00 for scrap and sticking to that right now. He might be right on the price, but I just can't see it, especially if the crank is ruined.
How far can that crank be taken down and still be reliable?
gtski
12-18-2011 18:58:53
 Re: 2670 Crankshaft - Need help/advice in reply to Lamont, 12-17-2011 20:51:56
Those 504 crankshafts aren't that hard to come by. $2500 is a cheap price, rough 2670s are in the 7-10,000 range.
Jerry he
12-18-2011 19:59:42
 Re: 2670 Crankshaft - Need help/advice in reply to gtski, 12-18-2011 18:58:53
Are you wanting to rebuild the 26 or do you have another use for the 504? We have had several cranks welded back to specs with no problems. If the tractor goes to scrap I would be interested in the 504 complete. Give me a call 217-343-1585
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea ... [Read Article]
Latest Ad: 800HD moline engine. Very nice condition. Put it back to work or use in a pulling tractor. 3500 [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
