2590 hydralic issue
hey all, i have a 2590 that works fine most of the time but once in a while wont raise an implement until you hit the incher pedal ( clutch pedal ) then works fine again? i'm afraid maby seal in c2 curcuit? sticky spool valve? any help would be great thanks
Check low pressure standby. Pressing the inching pedal causes a pressure drop which should tell the pump to increase oil flow. If low pressure standby is set too low, the pump will not get a signal to start oil flow.
(I hope this helps)
