Case Tractors Discussion Forum |
? for Case Nutty+MEL+other case experts
Author |
[Modern View] |
G.Fields
11-24-2011 16:15:15
Next rainy day im going to look at a 2090 with a good motor/bad trans(wont move) for 3500. Ive dealt with the guy before and can prob get him down to 2500. I know troubleshooting by computer is less than ideal but ive never been around a case. I was thinking if i get there and the power steering and hitch work, maybe its something simple? Or am i thinking wrong? Figured maybe you guys can shed some light on the subject. just wondering if this sounds like a run far+fast/ worth a chance/ or just no way to tell until you get into it? thanks in advance.
mEl
11-24-2011 18:39:56
Re: ? for Case Nutty+MEL+other case experts in reply to j hikemper, 11-24-2011 16:15:15
You would need to get more info. I have seen a couple pump drives go out and give a total loss of all hydraulics. The pump runs off the flywheel center and not through the TL plate so you should still have steering and for that matter tranny pressure and PTO action. I agree that a flo test would be a good tool to figure wich way to look but paying attention to what is still working will go a long way to an experienced tech. Plugging a flo meter into the remotes, testing the powershift in each range with the pressure in the remotes controlled by the flow meter to a pressure that will not kick out the spool holding detents, then comparing flow readings in each powershift range will allow you to see even small leakages in the different clutches. mEl
Case Nutty 1660
11-24-2011 18:30:59
Re: ? for Case Nutty+MEL+other case experts in reply to G.Fields, 11-24-2011 16:15:15
I would need more info to give much of a guess, I have seen from a brg out to torque limiter failure and every thing in between, as to the steering and brakes they run from a seperate pump piggy on the, main closed center system as the "90" series use a copletely different hyd system than the "70" series a "hands" on flow/ diagnostic test needs to be done to make a well edgucated guess, at least that is how I am able to do them and in the end only a tear down will show all problems completely, I find the flow test is usally the best way to tell where to dig sorry not more help, I hope mEl will chime in he may have another way to make a short cut cnt
Thad
11-24-2011 17:40:05
More than likely its the torque limiter hub has failed. I couldnt tell you how many we put in in a years time. Its very common on those tractors for it to fail. Thad
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
John Deere wheels rare pair of A1106R 24 inch solid cast rear wheels 3000.00. Pair of BWH / BNH 40 inch spokes 1600.00 pair of John Deere D front spokes 350.00.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
