am posting this for a friend. he has a case sc which runs great but he cannot get the tranny to go into any gear but second and reverse. any ideas?? any help would be greatly appreciated.
Re: case sc shift problem in reply to Don Deere, 11-21-2011 20:40:27
Pull shifter bolts and shifter , study shifter plates , use a pry bar and find more gears,, more than likely there has been too much shifting in last 60 yrs and the parts are worn creating slop ,, might be able to build up with welds and file to better fit ,,
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
