Case Tractors Discussion Forum |
Case 310 maintenance
Author |
[Modern View] |
Michael Donegan
10-09-2011 06:03:47
I have a 310 backhoe/loader. I purchased on ebay an operators manual in hopes of determining some base maintenance spec's, such as type and amount of engine oil, oil filter, to use and how much air pressure for the tires, but unfortunately found these spec's are not in the book. I was thinking of using 30 weight. Should I instead consider a multi-viscosity since I live in western NY and winter is approaching? detergent? Non-detergent? Any thoughts? Also, anyone know what air pressure to use in the tires? The fronts are 7.5 x 16, rears are 14 - 24TG. Thanks, Mike
700 man
10-10-2011 04:08:57
Re: Case 310 maintenance in reply to Michael Donegan, 10-09-2011 06:03:47
Case Dealer told Me one time Case engines called for straight weight oils,so thats what should be used.Oils are alot better nowadays,probably won't matter much,as long as its good diesel oil.
Stephen Newell
10-09-2011 07:53:58
According to the Case manual I have you use sae 30 at 70 degrees or more and down to sae 10 at minus 20 to +32 degrees, so I would think 10W-30 would be fine. A non detergent oil is normally used in place of hydraulic oil or in air compressors where you don't have the filth of combustion. Use detergent oils in the engine crankcase. I'm not sure which oil filter the 310 has. If its like the 210B its a strange looking thing that looks like a mason jar when off the tractor. The filter for the 210B is Napa 1106, AC 0412, Fram C-159. The tire pressure for the front tires should be 28 lbs max-44 lbs. The tire pressure for the rear tires should be 12 lbs.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Single front wheel assembly for 18-27 hart par
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
