Case Tractors Discussion Forum |
830 Distributor
Author |
[Modern View] |
ihr190
09-27-2011 15:22:23
The seals are shot on the distributor shaft on my 830. Leaks engine oil up to the points, then it dies. It is made by Prestolite. Dealer says that kit is no longer available. I wanted to switch it to electronic anyway. Any ideas? Thanks in advance. Rob
ihr190
09-27-2011 17:46:56
Re: 830 Distributor in reply to ihr190, 09-27-2011 15:22:23
John, I will look at that in the morning. thanks.
John Saeli
09-27-2011 16:58:05
There are no seals on the Dist. shaft. At the bottom are 2 bushings, & above them is a needle bearing. Replacing those would help. But, I think you have something else going on, such as too much blow-by. Is the vent tube running across the valve covers fully open?
ihr190
10-02-2011 15:53:57
Re: 830 Distributor in reply to John Saeli, 09-27-2011 16:58:05
John, the tube for the vents on the valve covers was dirty, but not plugged. I cleaned it out anyway. The valve train in general was pretty dirty. Lots of caked oil. How can I clean this? There must be something not letting the gases out of the crankcase below. Rob
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
