Case Tractors Discussion Forum |
injection pumpinjector swap??
Author |
[Modern View] |
Jason Weir
09-20-2011 09:12:19
Got 2 Case 188D motors - one from my 66 530CK with the CAV style injectors and the other from a 77 580CK with the pencil style injectors.
I want to use the newer motor in my 530 but keep my newly rebuilt injection pump - will it work? Are the pumps interchangeable? Will the older pump drive the newer injectors? Pop pressure the same between the old and new injectors??
If not, I guess my other option is to swap heads as well..
Thanks,
Jason Weir This post was edited by Jason Weir at 12:22:18 09/21/11.
Jason Weir
09-22-2011 05:35:32
Re: injection pumpinjector swap?? in reply to Jason Weir, 09-20-2011 09:12:19
The mEl - that's what I needed to know - the local shop will pop test my pencil injectors for free - if they test out ok I'll run them with my newly rebuilt pump.
Thanks,
Jason
Jason Weir
09-20-2011 13:05:26
Thanks - I appreciate the info..
So does my pre-pencil pump need to be adjusted\recalibrated to run the pencils at their higher pressure and what are the advantages (if any) of the pencil style injectors?
-J
mEl
09-22-2011 03:38:13
Re: injection pumpinjector swap?? in reply to Jason Weir, 09-20-2011 13:05:26
Jason Weir said: (quoted from post at 13:05:26 09/20/11) mEl said:
Jason The old style heads are no longer available from Case and havn't been for years. The fix was to get a new style head, injectors and lines and convert it to pencil. No new pump was required. Your injection pump is ok although the pencils do run at a higher pressure. mEl |
So does my pre-pencil pump need to be adjustedrecalibrated to run the pencils at their higher pressure and what are the advantages (if any) of the pencil style injectors?
-J |
No it will be fine as is. There is no significant difference between the bolt ins and the pencils. Pencils ran higher pop pressures but your pump wont know the difference if it is in good condition. More often than not the pencils will be replaced rather than rebuilt , while the old style can be retipped and reset by any shop that has a injector tester. Just a thought tho, the 580 pump may be set to a higher fuel delivery rate due to the power required to move the heavier unit around and running hydraulic loads with the front mounted pump. If you like the idea of more power you may want to consider using the later pump. If you would give a local pump rebuilder the numbers off both pumps they could tell you the difference in fuel delivery and rpms. mEl This post was edited by mEl at 03:46:32 09/22/11.
mEl
09-20-2011 12:59:50
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
John Deere 820 tractor in very good condition.2 owner tractor with original rear tires. 715 853 3669
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
