Twine type Case 230?
AGNut
New User
Just got a Case 230 square baler. It came with an old roll of hemp type twine. Is that what i need to use? Can i use the plastic twine or does it matter? Preciate the advice. Have a good one!
We use plastic twine but the knotters can't be too loose. And use the 9000 ft bales as the 16000 ft bales of plastic twine are too thin and break. Very good baler if properly adjusted and maintained.
Plastic twine is also more abrasive and the old style knotters do not last long when you run it either. New style knotters are hardened and chromed so take the wear better.
Jim plastic is all I have ever ran in my Case balers with no problems, we sold plastic with them when new so at least the Case knotters were designed to run both cnt
Tom, I ran plastic in my 230 and a 24T JD, both seemed to wear out faster than my Allis 303 that only runs sisal.
Jim, that does make sence as the sisel is some what oily ( only way I can describe it) and I myself do not like the sisel as the mice here have a hey day with it, so I do not have any time to compare it to thanks cnt tom
use either,,plastic wears the needle down ,, but you would have to bale 10k bales a yr for a decade before you would start havin problems ,,.. more square balers are sent down the river to new owners for knottin problems,, if you have problems find a PROIVEN qualified( NO Flunkie ) mechanic to make proper tunin adjustments ,, doesnt matter what brand or age , with correct tunin ,a 60 yr oldbaler can bale like a new one ,FOR MANY YEARS ,, OR BE JUNK IN adummies hands,, new balers?,, same story ,,
