Case nutty 1660
danjwv
Evening
Thought you might tell me if a 411b com distributor will fit in a 430 case triple range. Thought I'd use it if it will work.
Thanks for your time. Dan. Danjwv
I must be losing my mind I chnged the gear because it was shot, the camshaft from a vac willfit in a 530 engine so the dist will interchange too no probs, little to much Caseon the brain cnt
Case nutty
Thanks foe the response back to the distributor question.
Not to tight to buy a new one when a used one will do.
If your ever in my country ,stop in and I'll give you the tour
Thanks again. Dan. Danjwv
