some last minite haying
Case Nutty 1660
had a friend call and what some 2nd cutting alpha put up really nice hay and is real pretty up at his place,, blew a once repaired pitman arm ( not by me) not repairable so I ordered a new one 247.00 from Hesston should be here tuesday or so thats farming LOL cnt
That's not last minute haying. Last minute haying is when you can't see the windrow because the snow is blinding you!
It would be nice to have green grass, not brown and feeding hay. It will be a long time till spring! That is the way it is in south west Missouri. Nice tractors you have.
Is that a 14' Hesston 1014 you are cutting with?
What model rake is behind your 770?
I bought a 14' Hesston 1014 about 2 weeks ago, and now I'm shopping for a rake to match it.
Any suggestions?
yes it is a 1014 plus 2 a double sickle unit, and the rake is a 10 wheel 3pt model, it works fine on large field with gradual turns, if you have sharp twistys I recomend a pull type unit wheel or rollbar type as they will rake around corners well, also if you go with a wheel type I perfer a high-capicity one as they handel large windrows with less bunching cnt
Thanks for the info.
A lot of my hay ground is hills, so I need something that will work good going over terraces and around odd shaped fields.
I was considering a "pull type" V-rake of some sort.
I used a H&S high capacity rake this summer on a couple of cuttings and really like it, but the fella sold it to another neighbor (due to health issues) before I found out it was for sale.
