1950CaseVac
New User
I just got a new piston cup for my 1950 VAC Eagle Hitch from my local Case dealer (part A30798). I understand how to center the cup by inverting piston in cylinder. The problem is the new cup is made of hard rubber/fiber and is 0.12 inch larger than the cylinder. Cylinder is 3.75" and OD of new cup is 3.87". I can't even put cup into cylinder inverted (small end diameter of cup into cylinder first) as it gets stuck about half way. I just can't see how to get this installed. I thought about a piston ring tool, but can't get the compression needed on the lip of the new piston cup. I also tried to "soften" the lip of the new piston cup by rolling edge on my work bench. It's still very stiff. I'm about ready to take this $38 part back to Case because I think the Taiwan company that made it made it too large. And yes I did apply hyd. oil to cylinder, piston, and cup.
