Re: when is a 830 sleeve worn out in reply to Cyric30, 08-14-2011 19:03:27
If the sleeve is not worn too much, be sure to check the top of the sleeve and make sure that the top lip were the head gasket fits around is not burned away. The 830 I own that my Uncle owned had the tops of the 2 inside sleeves almost completly gone on one side and had to replace them. FE
I was told years ago that 10 thou. wear was the absolute max that was allowed for a re-ring job.Measure the bore at the top and the very bottom and that should get you the standard bore. Then measure the bore just under the ring groove where the rings turn around and see how much wear is in this area and also measure how much out of round there is. Nice new perfect rings won't seal in old out of round worn out holes. Also check pistons for ring land wear and the skirts for wear. If you re-ring be sure to cut the ridge completely out and hone and do a nice job in this area so you don't break the new rings.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
