Need Help With a 655 Haybine
RJKeith
I need to replace the cutter drive belt. Trying to get the old one off I have to get it past the flywheel and crank assembly. My manual says remove the bering flang and just lift it up. I removed the the top bearing flange and the bearing flange on the pivot arm rod at the crank. Nothing will lift up. Do I need to get the bottom bearing out, and how do you get to it? Or does the crank lift out of the fly wheel. I see what look like bolt holes, but there are no bolts or allen screws that I can find in them. Any advice on how to get this out would be appreacheated. Thanks.
