Christopher Mikesell
I have a case VAC-14 which originally had the under-tractor exhaust option, as evidenced by a set of mangled brackets under the left floorboard and an under-hood air cleaner. I would like to recreate this exhaust configuration but I cannot find any specific information on it, except for an illustration that was in some case literature. I can fabricate the exhaust elbow and exhaust pipe, but I need to know accurate pipe sizes, lengths, bend angles, and muffler dimensions. I would like to make this thing look and fit like an original if possible, rather than just making it look similar to the illustration. Also, I think the exhaust pipe exited behind the rear axel, since there is a mangled bracket hooked under the left-side eagle hitch mounting bolts.
