Author |
[Modern View] |
jon barton
08-08-2011 18:26:03
i have a case o matic 800 and there are some parts broken in the injector pump.. will the pump off of a case 400 interchange with that ?
1031D
08-09-2011 10:39:35
Re: case 800 injector pump in reply to jon barton, 08-08-2011 18:26:03
I am looking for the "T" with the valve in it on top of the primary filter and the foot throttle linkage
jonbarton
08-09-2011 12:25:05
Re: case 800 injector pump in reply to 1031D, 08-09-2011 10:39:35
i have both the tee and the throttle linkage from the pedal to the injector pump. give me a call to discuss it more..480-694-7649
1031D
08-09-2011 10:00:44
What's wrong with the 400's? I am looking for a couple parts for a diesel.
jon barton
08-09-2011 10:33:04
Re: case 800 injector pump in reply to 1031D, 08-09-2011 10:00:44
i have 3 400's ......one that runs and two for parts. the parts tractors are both diesels and have wide fronts... i also have a single narrow front for them.
1031D
08-09-2011 07:37:29
What is broken? The pump in my 400 broke the cam/roller assembly and it was only a $115 part for an upgraded replacement. The 800 should have a PSB rotary pump, single plunger, similar to a 400, but you might have to adjust the governor and fuel settings as the 400 was 251ci and the 800 is 267ci, and with the inline pumps CASE warned to not mix pumps as they were set different.
Den N Ms
08-08-2011 18:38:34
jon Is it an American Bosh PSB or A German Bosh pump?
jon barton
08-08-2011 18:55:21
Re: case 800 injector pump in reply to Den N Ms, 08-08-2011 18:38:34
i'll have to check.. if i can't read the tag is there another way to determine the type?
Den N Ms
08-08-2011 19:04:11
Re: case 800 injector pump in reply to jon barton, 08-08-2011 18:55:21
Jon, The American Bosh has a round rotary head where the 4 injection lines attach.The German Bosh is a inline pump.
jon barton
08-09-2011 09:54:24
Re: case 800 injector pump in reply to Den N Ms, 08-08-2011 19:04:11
the pump on the 2 400"s that i have are american bosch and the one on the 800 is also. i wasn"t sure if there were diferent versions for diferent sized tractors....can i use the 400"s as parts pumps for the 800?
