hi
i'm new to this site so hello to eveyone. i bought a case 580k which has 9000 hrs on it. i started doing some much needed maintenance. changed trans/hydraulic cooler in front,replaced all seals on 4 hydraulic cylinders.
i took out bottom drain plug on torque converter housing and quite a bit of oil came out. i don't think there is supposed to be oil in the housing. do anyone know what might be leaking. this is a phase 3 case with the shuttle being associated with the transaxle. any help would be appreciated
thanks in advance
thanks in advance
