Had the 1030 out the other day, power steering pump started pouring fluid out the front. Ball bearing junk, seal junk, and the pin that keeps the ring from spinning mostly sheared off, and the pulley grove is square from the PO running green belts from TSC in them. Has anybody replaced this pump with anything else? Looks like the Eaton pumps on old Ford cars from the 1950's. I see in the parts books the 730-1030 are the same pump but the 1030 used an 11/16" belt as mine is a late 1968. I would look in local salvage yards but whenever a 100 or 30 series shows up they either disappear or get picked clean real quick!
