Company Logo (800) 853-2651 Shop Now
Auto-Lite generator 12 volt conversion
Gene Dotson
06-26-2011 16:49:40
I just finished the 12 volt conversion on my Case LA. The repair shop
replaced the 6 volt fields with 12 volt fields. It is an Auto-Lite generator
and the 12 volt fields came from Ace and is part number 145 from them. This
generator is the same as used on SC and DC tractors, so this may be of use
to some others. The original regulator was used as mounted on the generator
and adjusted to 13.6 volts, so installation uses the same wire to the
ammater. I replaced the ammeter while I was doing the change. The battery is
a group 31 with center posts and replaces the original group 4, 6 volt
battery. This tractor has been built up with 4 7/8 sleeves and LP head for
about 90 horsepower, so the original 6 volt was not up to the task of
starting the engine. Cranks over very good now.
Gene
This post was edited by Gene Dotson at 19:23:03 06/26/11.
DKase
06-26-2011 18:27:47
 Re: Auto-Lite generator 12 volt conversion in reply to Gene Dotson, 06-26-2011 16:49:40
26.6 volts? I'll bet it cranks! What does that do to a 12 volt battery? I hope that was a typo.
Gene Dotson
06-26-2011 19:22:29
 Re: Auto-Lite generator 12 volt conversion in reply to DKase, 06-26-2011 18:27:47
Yep, sure was a typo. Guess I should have done a better job proofreading. Should have been 13.6 volts.
Gene
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea ... [Read Article]
Latest Ad: John Deere DUBUQUE Parts for sale- 24 inch power adjust rims, 3 point hitch parts, Utility Rockshaft, Utility Anchor Yoke, 40 Standard ring and pinion, various 40 transmission gears. Other DUBUQUE parts available. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
