2470 3pt parts
on a 2470 im removing everything to the 3pt for somebody to install one on theirs. i know i need the part for the linkage. the cylinders, arms ect, and lever. which lever would it be seeing the decals have worn off on the lever box. where is the control valve located and how hard is it to remove. is there any other parts i missed to run the 3pt. thanks
Mark the lever closest to the seat controls the DOM, the DOM valve is seperate also but am sure you knew that cnt ps if you want I think I could scan the ops for a shot if you like
also if you haven't yet I would take the steps as they come in mighty handy
they are not sold yet but sombody in ontario canada wwants them and is giving me $500 for them. if he dont endup taking them i will let you know but he seems pretty interested in them. i had another guy call me today for a part that picks up the 3pt so im not exactly sure whats happening yet. i got to get everything removed. the steps on the tractor arent in the greatest shape but they might work. they are kind of mushrumed on the bottom from rolloing it from side to side. i could take pics if you like.
sorry i forgot to ask what is the DOM. so the lever that picks it up is closest to the seat. i almost wish my 4490 was here a little longer so i could look on that. anything and everything is forsale on it.
Mark sorry didn't mean to confuse ya hope this blows up good for you cnt
sorry Mark I did not say if you look at the rockshaft it will have a rod with a ball joint on it follow this forward about a foot and the hitch (COM) valve it hooked to this rod to gain acces remove the steel plate below cab window on tractor frame this gives you access to the remote valves also, in the parts page I added the valev is item #33
Mark I should read my typing better before I post I see I listed that Draft-o-matic valve as a Case-o-matic, Duh, and actually it has a depth control valve as the four wheel drives did not have DOM, but it does use the same valve just for depth/height control not draft, now that I have you totaly confused I hope that makes sence cnt tom
