case 430 crankshaft
Anonymous-0
my old 430 [gas] had a severe lower engine knock and upon tearing it down found that #4 rod bearing was completely distroyed and had worn the crank down considerably' and found that the other bearings were well on there way out. i realize that i could have the crank built up but i was able to get what is suppose to be a good crank.. my question is does anyone have the specs. for this crank and also the clearances.the crank has 3 main bearings and has the# g11740 stamped on it. thank you for any help sam
Sam
The following are scans from the 430-530 OEM service manual. - Joe
hey Joe sorry didn't mean to double up and yours is much easier to read I 'll let you catch these Rock Island babies from now on thanks cnt
