Company Logo (800) 853-2651 Shop Now
2090 Air conditioning
pgarrett
06-10-2011 08:07:37
I pulled the top cover off the cab to do some cleaning.(Was not getting much air flow out of the AC vents)There is no duct work from the blower motors to the evaporator and heater core.Am I missing parts? Does the open area in the top of the cab act as the duct work ??
Eagle Claw
06-11-2011 05:21:04
 Re: 2090 Air conditioning in reply to pgarrett, 06-10-2011 08:07:37
there is apiece of insulation between the top cover and the rear filter that can fall down and cut off air flow to the fan. rip it out and discard
John Saeli
06-10-2011 18:33:57
Also, before you put the lid on, be sure to seal anyplace air could leak out, such as around the speakers, wire holes, ect. Seal everything up tite, and air flow out the louvers is pretty good.
casemagnum
06-10-2011 09:11:46
It blows out of the blower motor housing and through the top of the cab and across the heater core and evaporator. There is nothing wrong. Just make sure the pan under the evaporator core is clean and the hoses under the evaporator core that go through the front 2 cab posts are clean so that they drain and remove the water from under the evaporator core or else the water will fill up under the evaporator. That will cause the AC not to work as good and eventually enough water will build up that it will run inside the cab and give you a bath. Also make sure when you put the lid back on the top to either put a new seal on or silicone or caulk around the top very well to prevent air from getting out and to keep the rain/snow from getting in. It also helps to silicone or caulk around the bolt heads to keep the water out also. Hope this helps!
pgarrett
06-10-2011 12:02:38
 Re: 2090 Air conditioning in reply to casemagnum, 06-10-2011 09:11:46
Thanks for the help.
cshess
06-10-2011 18:03:35
 Re: 2090 Air conditioning in reply to pgarrett, 06-10-2011 12:02:38
Make sure the cage fan blades are not full of built up dust making fan inefiicient.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: 2 early 1950s Dodge Pickup Trucks flathead 6 engines 4 speed stepside boxes havnt run in 35 yrs Good restoration prospects or parts Price 600 each can hold till late fall for buyer. calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
