I hit a rock bush hoggin with a 15 foot bush hog with my Case 770. The 1000 rpm output shaft quit turning. After taking the shaft out and puttin it back in it worked for 5 minutes and then quit workin again and made a kinda light grindin noise.
The output shaft works when the 540 end is used in the outboard position. Is there an easy fix? The bush hog sure does a nicer job with the 1000 PTO shaft outboard.
