1030 hydraulic leak
Anonymous-0
My dads says his 1030 is leaking hydraulic oil from the area where the brake actuation rod goes into the rear end. It is a major leak. He says it is almost like it leaks out so fast it seems it is pressurized,
Can you give us an idea??
Thanks
Not really, you could pick them out after removing the brakes. The pinion bearing carrier is sealed with an O-ring but the service manual recommends supporting the differential to prevent damage to the seals and bearings if removed.
