Case Tractors Discussion Forum |
DC Clutch or should I say no clutch
Author |
[Modern View] |
Paul Simmer
06-02-2011 18:37:23
While disking the garden tonight, it appears the clutch went out of my 1950 DC. Pretty much stopped in its tracks. At first I thought it jumped out of gear, even though it never has. I shut if off, restarted it and it moved ok but only a little ways. Not I have a growl, grating noise and no movement. I suspect something broke. It appears there is an inspection plate on the side near the clutch linkage, is there anything to see in there? I am sure it will need to be split and a new clutch put in. How bad of a job is it? Thanks in advance.
D Standard
06-03-2011 20:28:19
Re: DC Clutch or should I say no clutch in reply to Paul Simmer, 06-02-2011 18:37:23
My dad teaching me to pull "right" on some overgrown boxelders twisted the center out of the clutch on my 1950 DC (sheered rivets). Following the manual was easy and worked good. The only thing I would recommend is making pins 20 inches long and using them as guides only, use jacks and blocking to split tractor. Be sure to brace front from tilting.
Paul Simmer
06-03-2011 07:16:52
I would appreciate the service manual and any other hints. What are the splitting dowel/aligning pin size?
Paul f
06-04-2011 07:21:34
Re: DC Clutch or should I say no clutch in reply to Paul Simmer, 06-03-2011 07:16:52
The pins are 3/4" round stock. Manual has some super-precise length. I got a 4' section of stock and cut it in half. Gives you more room to work, but support tractor with jacks do not rely on the pins alone.
Case Nutty 1660
06-03-2011 07:35:58
  here the spliting steps and pin lenth, as to diameter they are the size of your aliment dowel pin cnt
Paul f
06-03-2011 05:36:17
    As Case Nutty said the aligning pins make the job not too hard. Just did my DC last year. While you are in there check the transmission input shaft for any play. Mine had gotten a bit noisy as you can see the bearing was toast...but she still ran!
Case Nutty 1660
06-02-2011 19:31:57
just a guess but I seen one set of facing get loose and sheared the rivets on the lining yours problem may be simalar, as to the split, if you like I think I could scan my "D" series servise manual on the steps, you can make a set of spliting dowels they work very well, and make a clutch job a breeze cnt tom
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
Rebuilt 1979 Ford Truck Rockwell Rear axle. This axle will also work as the rear axle in a tandem set up. This is out of my F700 and is a single speed. Rockwell with 6 hole wheel lugs.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
